In Tracking, I use a “Checklist / Milestones” type attribute to manage a list of mitigation measures associated with a validation request (each measure being a step/milestone to follow).
I would like to set up a view that allows direct display, for each record, of the complete list of steps in this checklist, without having to open the record.
Question: Is there a configuration, a view, a component, or a feature (standard or via parameterization) allowing:
to display the content of a “Checklist / Milestones” attribute in a view (ideally the list of steps, and if possible their status);
or, failing that, a recommended alternative (e.g., table/kanban with sub-items, dedicated widget, enriched “detail” view, another more suitable attribute type)?
Usage context: I want to have a global overview of mitigation measures across all requests, to facilitate tracking and avoid having to enter each record.
Thank you in advance for your feedback (screenshots or configuration examples are welcome).
Yes — for this need (to see all the steps of a Checklist / Milestoneswithout opening each item), the most suitable standard solution is generally the KANBAN view.
Why Kanban is “ideal” in your case
In a Kanban view, cards are highly configurable: you can directly display the “Checklist / Milestones” attribute (the list of steps, and depending on the settings, their progress/status) on them, and interact with it directly from the card (without having to open the item).
Recommended Configuration (simple and effective)
Create (or duplicate) a view → Kanban on your board
Choose the grouping
Open the card display settings
Add the “Checklist / Milestones” attribute to the card to see all the steps in one place
If you have many measures (or need assignments, dates, comments per step), you can also extract the mitigation measures into a dedicated board linked to risks (1-N relationship): you gain sub-item management, while maintaining a consolidated view via views and indicators.
