In a recent forum exchange, a user was looking to build a prioritization matrix with a KANBAN view: the columns represented a score (1 to 5) and the goal was to display actions with the highest impact / highest priority first.
While waiting for the addition of a dedicated option to sort columns in the KANBAN view, there is an interesting workaround by using the Matrix view.
The need
An “impact” axis
A “priority” axis (or score 1–5)
Ability to visually identify “high impact / high priority” items.
The solution with the Matrix view
Create a Matrix view on your board.
Assign your Impact field to one axis (X) and your Priority / Score field to the other (Y).
The Matrix view automatically sorts both axes from smallest to largest.
In the Matrix options, use the fields “X lower label” / “X higher label” and “Y lower label” / “Y higher label” to make reading clearer, for example:
X lower label :
Low impact -
X higher label :
High impact -
Y lower label :
Low priority -
Y higher label :
High priority
You thus obtain a matrix that highlights, in the same quadrant, actions with high impact and high priority.
It’s not exactly the same visual as a KANBAN, but by playing with the axis labels and item display options, you can achieve a very readable prioritization view that is directly usable for arbitration.
Feel free to share your own matrix variants (impact / effort, value / risk, etc.) in this thread ![]()
